  • 32 Replies
  • 6516 Views
KachinaShadow
Prodigy
Prodigy
@BrookeN
I'm not sure where to start because there's so many issues here...this involves two other posts of mine, that you've been involved in.
As you know, in another post  Re: Security Light Not Turning on Light with Motio... - Arlo Community  which went into the strange goings on with two Security Lights no longer turning on the light or cross-triggering the corresponding cameras. That, along with me finding actions, in routines, disappearing or turning off...which is how I found the Pro 5S "record video" slide switch turning itself off and no longer able to be turned on Pro 5S Live Streaming Issue - Arlo Community
After spending the past two full days installing/uninstalling the two lights and the two cameras multiple times along with rewriting, over & over, the corresponding routines (those lights cross-triggered the Pro 5S, mentioned in the other post & a Pro 3) I've found the following...the routine for the lights both managed to turn the brightness to low (so they wouldn't light at all) in a setting that does not appear in routines on the app but is pretty much hidden in routines on the web portal and only appears when you click on an arrow to the right of the "turn on a light" action. By turning those both up, the lights now both work, but will randomly quit and have to be turned back up...light issue partially solved.
 Here's what I've found with the videos not recording with motion sensed by the camera. As you know, from the one post, the Pro 5S "record video" slide switch would turn itself off and not be able to be turned back on (without uninstalling/reinstalling the camera) but even with the slide switch slid off the camera was still able to be cross-triggered by the corresponding light and would record...this was originally exclusive to the Pro 5S but today I found that the Pro 3, triggered by the other light, now has the same issue with the record slide switch. Now, with the issue of the videos not recording when cross-triggered by the lights and with all of the uninstall/reinstall of both the lights & camera, I found that all of a sudden the videos were recording when cross-triggered by the lights and I couldn't figure out why, until I was satisfied that the lights were now working and I put the "activity zones" back in and, you guessed it, no more video recording. Note that I've always had activity zones on those two cameras and by setting the videos triggered by the camera to 40 seconds and the videos cross-triggered by the lights to 45 seconds, I could always see that both were working. After I found this issue, I confirmed that it wasn't just these two cameras by setting up the doorbell to cross-trigger some other cameras with the same results...video recorded without activity zones, no video with. Note that if you try to set up a cross-triggering routine, after the record slide switch has slid itself to off, the device that you're trying to cross-trigger no longer shows as a selection of available devices and then you have to uninstall/reinstall that camera to get the slide switch on and set up the routine.
So, the issues here (that I was led to by the lights not working weeks ago) seem to be two things...routines changing and sometimes eliminating actions along with cross-triggering no longer recording when activity zones are set on the camera that is cross-triggered.
Seems like there's so many issues and variables that I've found in the past two days, it's hard to keep track of.
Paul
KachinaShadow
Prodigy
Prodigy
@BrookeN @StephenB
Good news!
Last night I noticed that I was no longer receiving notifications from the lights, so I spent some time testing all of the lights and found that the issue is resolved.
All but two lights had to be removed and re-added before they realized the fix.
32 REPLIES 32
KachinaShadow
Prodigy
Prodigy
@BrookeN
Thinking about this...it all started about three weeks ago with issues that I blamed on the Security Lights  Re: Security Light Not Turning on Light with Motio... - Arlo Community  when, now that I've looked at everything, it seems to all come back to problems & changes (without me doing them) in "Routines".
Same with the unusual behavior that I was blaming on the Pro 5S camera  Pro 5S Live Streaming Issue - Arlo Community  when, two weeks ago, while on vacation, I found that the record slider had turned off and couldn't be turned back on, which also seems to also come back to problems with "Routines" (record slider turning off, light flashing when set to constant, no cross-triggering recordings when activity zones are set) and it now seems to be affecting other cameras, like the Pro 3 now turning off the slide switch in routines.
I'm about out of ideas...I removed and reinstalled cameras & lights and rewrote the routines numerous times, along with rebooting the bridge & VMB5000r4 Smart Hub over and over and removed and reinstalled the app at least four times.
Also, here's something else that has to do with routines, although it has to do with the web browser  Re: Unable to Add Action in Routines on Web Portal - Arlo Community
After two days on this I'm spent ☹️...but feel free to have me try anything that might give a clue as to what's going on.
Also, is there another email that you'd like me to send that zipped log file to, other that the two that I tried where the attachment didn't come through.
Thanks,
Paul
KachinaShadow
Prodigy
Prodigy
@BrookeN
First off, forget about the cross-triggering/activity zones problem. That was 100% due to my stupidity...I had brought the two Security Lights into my office to put them under the desk, where it was dark, so that I could resolve the light issue, which I did. Problem was that after two days of removing & installing everything, the last thing I did when I was done was to put the activity zones back in and doing one last test on everything, not even thinking that if there was no motion in the activity zones of the triggered camera, then it wouldn't record...sorry 🙁
That said, while hiding my head, there are the two issues which still remain...
First is the Security Lights setting in "routines"...I know the lights are at EOL but they work just fine, it's the routine that only shows on the web portal, and changes at will, that keeps the lights from lighting with motion.
Like I mentioned in the first post, the routine for the lights managed to turn the brightness to low (so they wouldn't light at all) in a setting that does not appear in routines on the app and is pretty much hidden in routines on the web portal and only appears when you click on an arrow to the right of the "turn on a light" action (pic 1). By turning that up, the lights now work but will randomly quit and the setting has to be turned back up (pic 2). I had this change on me two times today and a few times yesterday.
Also note that with the current issue, on the web portal, of being unable to add actions in routines  Unable to Add Action in Routines on Web Portal - Arlo Community  , you have to setup the routine in the app, then return to that same routine in the web portal to turn that setting to the desired brightness or the light will not light up from the get go.
Second is the camera setting in routines, the "record video" slide switch would turn itself off (pic 3) and not being able to be turned back on (without uninstalling/reinstalling the camera) but even with the slide switch slid off the camera was still able to be cross-triggered by the corresponding light and would record. Of course, with the switch off, the camera will not record when it senses motion...only when it's cross-triggered from another device.
Screenshot 2025-10-15 182731.jpgScreenshot 2025-10-15 181412.jpgScreenshot_20251016-153739.Arlo Secure.png
BrookeN
The behavior you are explaining is already being looked into. I will reach out as soon as I get an update for you.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Just a quick FYI...maybe it will help someone (or not)
This morning, I uninstalled both cameras and both lights then reinstalled only the cameras in order to eliminate any possible issues with the lights.
Ten minutes after setting up the routines, I tested the motion recording and found that the South camera (Pro 3) had already turned off the "record video" slide switch and around 10-15 minutes later the North camera (Pro 5S) "record video" slide switch had also turned off.
Thanks, Brooke, for all you do 😊
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
Out of curiosity, I readded the two cameras which have the turn "record" slider off in routines issue, just to see if they still exhibited the same behavior. Within 10 minutes of setting them up, in routines (standby & arm away), they both turned "record" off, so I got to thinking what do these two cameras have in common that my other five cameras do not, in respect of how they are powered. Note that they still detect motion and send a notification, along with still being able to livestream.
Devices that DO NOT TURN OFF in routines...
  • Doorbell - wired
  • Ultra - wired
  • Pro 3 - wired
  • Pro 5 - battery
  • Pro 5 - battery
  • Ultra - battery
Devices that TURN OFF in routines
  • Pro 5 - Arlo solar panel
  • Pro 3 - Arlo solar panel
I can't imagine that having solar panels, to maintain the batteries, would have any effect as to why these are the only cameras that have this issue, but who knows. Also keep in mind that the Pro 5 had this issue almost three weeks before the Pro 3 developed the same issue, which is really odd.
Paul
BrookeN
@KachinaShadow the Pro 5 is a known behavior that is being looked into. I do not have an update on that at the moment. For the Pro 3 connected to solar I do not think that camera was associated with the behavior you are seeing. If you disconnect the solar from them for a does the same behavior happen? Or is it only when they are on solar?
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
I've tried everything I can to try and find any kind of pattern or similarities with this multitude of issues, but I've got to tell you that I'm going crazy trying to come up with any rhyme or reason as to what's going on with these cameras & lights.
I uninstalled/reinstalled that Pro 3 (without solar), set up a routine and once again the "record video" slide switch had turned itself off within 10 minutes that, at this point, leads me to believe that there's something screwy with routines, which really leaves me confused since I have two other Pro 5's and one other Pro 3 that are setup in routines and are working perfectly. Like you said, the Pro 5 has a known behavior issue, but it seems very strange that this one Pro 3 has the same exact issue as my one Pro 5.
Also, the fact that this all started around the same time (other than the Pro 5 & Pro 3 issues surfacing almost three weeks apart), including the issues with the Security Lights. I know, the Security Lights are EOL, but the problem with them seems to be with routines and not with the lights. Note that I did find two new lights (new old stock, still sealed in the original packaging) which did update to the current firmware and onboarded just fine, but they have the same issue as the other two lights with having to go into routines, on the web portal, and set that previously mentioned "brightness" in "light settings" before they will turn on the light. Also note that when I was trying all four of those lights, even though "send notification" is turned off, they still send push notifications. I do have one other Security Light which is on "wired" power and it has the "send notification" turned off and does not send push notifications...it also turns on the light without having that brightness setting, in routines on the web portal, being set. Note that the four lights, that have to have the web portal/routines brightness slider set in order to be able to light, will totally at random turn off that brightness slider...could be within hours or days, there's no set pattern.
This may or may not be related but here's another "routines" issue that I found the other day Re: Unable to Add Action in Routines on Web Portal - Arlo Community
Paul
KachinaShadow
Prodigy
Prodigy
@BrookeN
One thing I forgot in the preceding post, regarding the lights, is that the lights that are having the issues in "routines" are the al1101r3 version and the one light that has no problems in routines, and hasn't changed, is the al1101r4 version.
Something has changed in "routines" that seems to only effect the al1101r3 (as proven by trying four of them with the same results) and not the al1101r4 and regardless of which version, or if they're EOL, they should all still be compatible with the "routines" setup in both the app & web portal, since Arlo allows you to onboard the "Security Light" with no specificity of version.
Paul
BrookeN
I am looking into this I will update you as soon as possible.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Thanks Brooke,
I did forget to mention one unusual thing with the lights, which may or may not be helpful to someone...when onboarding the lights and after setting up a routine in the app, then going back to routines in the web portal to set the brightness, the light will still not light up unless you restart the bridge. This holds true for every light upon installation.
If someone needs any further info from me, let me know and we can arrange a call.
Paul
BrookeN
With the newest update are you seeing any change in this behavior you were seeing?
KachinaShadow
Prodigy
Prodigy
@BrookeN
With the newest update the video playback is now smooth...I replied in the other thread about that.
As far as the update in regard to "routines", give me a couple of days to try all of the scenarios associated with settings in routines and I'll let you know.
So far I've noticed that the two cameras (Pro 5 & Pro 3) DO NOT shut off the record slider but I did see that a couple of the lights wouldn't light up this morning because that "hidden" brightness setting, in the web portal, had changed to zero and when turned up would again light the light but that was this morning with lights that were installed prior to the update (I had removed and reinstalled 4 lights yesterday and two of the four, surprisingly, did not require that brightness setting, in the web portal, to be addressed...which would be normal). Also, those two cameras seem to be able to, once again, be cross triggered from the two corresponding lights.
Since the update is now showing, I'll reinstall ALL of the lights in the morning, test them and run through some setups and let you know...what I've seen so far looks good 😁
Paul
BrookeN
Thank you for the update. Let me know how your testing goes.
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
Looks like most everything is good with the new firmware...recording, cross triggering, security lights, etc. There is however a problem with the Security Lights push notifications...they are not able to be turn off.
I have seven Security lights...three are currently in use, the other four were recently purchased to confirm if the previous issues were the lights or the firmware (it turned out to be the firmware). All seven lights onboarded just fine and have tested to be working as they should, with the exception of when the "send notification' slider is set to off, they still send push notifications.
The only way to silence them is to "mute" ALL push notifications but what's interesting about that is that unlike the cameras which, when ALL notifications are muted, do not send any push notification, the lights continue to send a silent push notification to the phone with no sound (so technically they do not totally mute like the cameras). In the past, when the routines (app) were functioning correctly, I would set the lights to not send any notification since they would be triggered by any wind blowing the plants, unlike the cameras with "activity zones"....last night we had some wind which constantly set off the push notification for the lights, which had been set to off, so I had to "mute" ALL notifications which, as you know, prevented any notifications coming through from the cameras. Needless to say, this is certainly not good and needs to be addressed since it makes having the lights pretty much useless if they require that all notifications, from any device, be muted.
I'm sure you noticed my comment in the other post regarding the stuttering/hesitating video playback not being fixed with the new firmware...maybe Jeffrey (L3) could shed some light on that.
Thanks,
Paul
KachinaShadow
Prodigy
Prodigy
@BrookeN
A little more info on the previous post...
Do you remember back in early 2024 when there was an issue of the Security Lights not detecting motion?
I went back to the thread on that issue Arlo Security light - No motion detection - Arlo Community and found that when the problem was fixed, my Security Lights which had previously been setup in a different configuration and had a couple of them set to "send notifications", would still continue to send notifications even when all notifications were muted. At that time, I just turned off the "send notifications" for each light and left it at that, although I did continue to check on this for months but since it was never resolved, I just left "send notifications" off...see my reply to your question in the pic below.
Of course, when this recent firmware update was installed my lights, which "set notifications" had remained off all this time, are now sending push notifications regardless of them being set to off and so now I have no way to stop that unless I mute all notifications which, as noted in the previous post, pretty much renders the whole system useless...kind of the opposite of what happened back in 2024.
Paul
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
Thought I'd just shorten up the history of what the remaining issue is, so that it makes more sense to anyone reading this...
  • Prior to the early 2024 issue of the "lights not detecting motion", the light's settings all worked good...Send Notification On or Off (routines) & Mute Notifications (for all devices) all worked as intended.
  • After the 2024 issue of the "lights not detecting motion" was resolved (first week of April 2024), the lights Send Notification On or Off (in routines) continued to work as intended, but if the Send Notification slider was "On", the lights would still continue to send push notifications even when Mute Notifications (for all devices) was on, but at least each light could be turned off in routines...not ideal but at least I could silence them, which was what I had done from 2024 up until this latest firmware update was installed on 10/27/2025.
  • When the current firmware was installed, the lights now continue to send push notifications regardless of whether Send Notifications is On or Off and/or Mute Notifications is on or off.
I'm almost to the point where I'm about ready to remove the lights from the system even though they are not only used as lights but are also used to trigger certain cameras. I really hate to do that since, as you know, I purchased some additional lights for testing, after this whole problem (lights not connecting, recording shutting off...all at random) started with routines and, since I proved that there was nothing wrong with my lights, I had intended to add those additional lights to my system so I hope this firmware created issue is resolved soon so that I can add the additional lights and not have to deal with unwanted push notifications all the time.
Paul
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
I'm sure you're probably tired of hearing from me 😉 but, I've got to say that I hope that this issue of not being able to turn off notifications from the Security Lights, which started with the last firmware update, gets fixed soon because it's driving me absolutely nuts and, in fact, at this point it would suit me just fine if they'd just disable notifications from the lights all together.
I currently have three lights in the system (one stand alone and two that trigger cameras) so I tried removing all actions, from routines, for the stand alone light on the front of the garage, since it's the most annoying due to cars driving by, and I set it up to trigger from the camera near it but, like any light that's triggered by a camera, there's a delay unlike having instant light when the light itself would sense motion...needless to say, that's not ideal although at least I don't get notified. There's nothing I can do with the other two lights since they actually trigger cameras, so they still notify me but they're on the back of the house and only get triggered by the occasional racoon, skunk or bobcat that wander down at night.
Of course, as you know, I had purchased two additional pairs of lights in order to try to figure out if some of the many recent issues with the lights were app related or light related, which the firmware update ended up solving (along with the record issue) but resulted in this not being able to turn off notifications from the lights problem. So now I have four perfectly good lights which I'd like to incorporate into the system but can't really do so until this newest issue gets resolved, since the last thing I need to do is add more annoying notifications to my life that can't be turned off 😜
I know you always do, but please keep me updated on this issue.
Thanks,
Paul
BrookeN
I know you have answered these before in previous threads, however I cannot seem to locate which one. If you wouldn't mind providing this information:
App Version: [Version]
Platforms: [iOS/Android/Web]
Firmware Version:
KachinaShadow
Prodigy
Prodigy
@BrookeN
App Version: 6.5.2.6050402 (10/20/2025)
Platforms: Android
Firmware Version: 15
BrookeN
Can you send me a screenshot of the notifications? You can send them DM.
KachinaShadow
Prodigy
Prodigy
@BrookeN
This morning, I installed the app on another phone which has Android version 13, and it had the same notification issue as the other phone with Android 15.
I'll PM those screen shots to you.
KachinaShadow
Prodigy
Prodigy
@BrookeN
PM with five screenshots sent
BrookeN
Thank you!
KachinaShadow
Prodigy
Prodigy
@BrookeN
Hi Brooke,
Is there any update on this issue with the Security Lights sending push notifications regardless of any settings to not have them do so?
The only way I have to not get notifications from the lights is to go into "settings" on my phone and turn off all Arlo notifications, which means that I will receive no notifications from the cameras. This was especially concerning for the past week while I was out of town and arm away mode (all devices) was active, so I had to turn off all notifications from Arlo.
When I'm home and in "arm home" (during daylight hours) there's not a problem since I do not have the lights included in the "arm home" routine. When I'm in "standby" (sunset to sunrise) there is not as much activity for motion to affect the lights, so I just deal with the push notifications from the lights unlike, as I said, when in "arm away" when all day long I get push notifications from the lights with every bird or animal and even plant movement with wind or a slight breeze since, of course, lights have no activity zone to ignore the plants like with the cameras.
Keep in mind that this issue started with App Version: 6.5.2.6050402 (10/20/2025), which solved the issues that this thread was originally started for.
Thanks,
Paul
