Is it possible to undelete videos?
Nope. NEVER delete videos for exactly this reason.
Plus 1 with above.....
the rolling storage will auto delete, So why bother to delete.
And download locally anything that may be important... if running a newr base ( 4000 model ) it's cheap to put a speed stick in the rear usb portand save all your videos... don't believe they are deleted if you delete from the cloud.
Jeff?? @jguerdat
Correct. Only cloud recordings fall off at the end of the number of days in your plan. The Pro bases with a USB drive continue to keep the recordings.
