  • 7 Replies
  • 3886 Views
JanAlbay
Is Arlo Netgear site down? July 3 2017 Cams won't record nor go live
It's 730 am Alaska time and Arlo cams won't record nor go live; is Arlo Netgear site down
7 REPLIES 7
manfredz
Hero
Hero
my cams recording ok and showing up in library.  Maybe problem at your end.  Are all 3 lights green on your base station?
pandamanda
Mine is also down and not recording either! (California)
manfredz
Hero
Hero
same question pandamanda, are all three light on your base station green?
pandamanda
Yes all green and solid
manfredz
Hero
Hero
have you two tried rebooting the base station?
next to try:
turn off base station and your router and/oror cable modem
wait 5 min
turn on cable/modem, router
wait 5 min
turn on base station
pandamanda
Yes and now I only have two green lights. What does it mean on the camera if it blinks blue and then flashes orange?
If the green LEDs are for power and Internet, that means no camera is synced. The camera LED blinking blue and then amber implies you're trying to sync the cameras using the sync button.  If that's what you're trying, just briefly press the base sync button - don't hold it.
