Internet speed for Arlo question.
I have CenturyLink as my internet provider. As of now have the speeds of 18 Down and 1 Up. We have 2 cameras set up at 40 and 48 feet from modem and Arlo home base. Even after getting customer support help yesterday, still having same issue. Which is that the recording doesn't start till after motion sensor is activated, which is no good. Didn't think that the distance is to far when I first bought unit. Is there anything I could do so I can keep these cameras? Any help would be great. Thanks!!
The lag may not be just due to your upload speed , but may be a setup problem... BTW, min recommended is 1Mbs up
It can be trial and error in setup AND there is a lag on the Alro cameras from the trigger event to the record start. ( low of 2 to 10 secs with some users )
So, try and capture a small area with the motion crossing the field of view as oppsed to straight on... also the sense level is adjustable by editing the Mode your using.
In one of my setups, I move the camera placement from the door to about 10 feet back aimed at the door... this allowed the subject coming in to trigger the record and even with lag, the subject was seen at the door and exiting.
Thanks - Sean
