  • 8 Replies
  • 6367 Views
Amb46
Ls,
About 2 weeks ago I installed a base station and a camera. The first week it worked perfect. But a few days ago the base station lost the internet connection. Whatever I do it doesn't work. The LAN light doesn't start burning/blinking, not even in amber. On the other side of the LAN cable in the router, there is a green light burning. So my idea is that there is something wrong with the LAN port of the base station.
What can I doe about that (besides going back to the shop and get another base station)?
Amb46 wrote:
That's not the case. On the router side the green led from the LAN is burning. But yes antoher device is working on that.
So it must be in the base station I guess?
If you have tested the SAME port and cable on a different device and that device works, then yes it's on the base side ( the trouble/problem )
As to proper location Arlo trouble shooting goes here;
https://community.netgear.com/t5/Troubleshooting/bd-p/arlo-troubleshooting
But, since you tried the reset and reboot and still no joy, I'd contact support at Netgear for a trouble ticket
http://www.arlo.com/en-us/support/contact.aspx
8 REPLIES 8
The LEDS on the base ( from left side ) are POWER, INTERNET, CAMERAS.... and all three should be green.
The first thing to do is a reboot via the power button... takes about  2 mins +/- to reboot
If this doesn't fix it, the do a full factory reset.... This is with a paperclip - hold in the reset button (back of unit ) for about 10 secs till the front LEDs flash
You will then have to re-sync the cameras as if new.
I
Amb46
I tried that too, with the same result. No internet connection!
What are the base station LEDs showing?
Amb46
Only the power led is green the rest nothing
it is obvious the Base station isn't getting internet.... ( as no second green led )
You stated the lan lost power at the beginning of this trouble.... Is it possible the lan is out?
Test the port and ethernet cable by plugging it in another device ( like laptop ) and see if the port outbound actually works.
BTW, this is in the ARLO Q section  where it may confuse a reader
Amb46
Amb46
Oh, am I in the wrong section? Where does this belong?
