We are on satellite broadband with a limited allowance. Can anyone tell me how much allowance would be used with 2 cameras Thanks
Depends on how much you view them or record.... live viewing or recording is the same usage.
The 10 second clips run aprox 900Kb to 1Mb of use.
If your using them for security, almost no bandwith unless you trigger a recording.
Thanks very much
