International Use
  • 4 Replies
  • 4134 Views
AprilMay
Will the system that I purchased in the US work in New Zealand?
steve_t
Master Master
What's the voltage rating on the power adapter? I'm in NZ and my power adapter says it is only for 240V. If yours says 100V-240V, it would work with just a power plug adapter, otherwise you'd have to buy a step down transformer or new power adapter here
AprilMay
Hi there,
Thanks for that, however I was more thinking about internet connection rather than power as I do already understand about power differences.
Are there any international restrictions for connectivity?
Not unless your ISP and/or country blocks access for some reason.
AprilMay,
If you understand the power differences, there should not be an issue. Some countries are limited to the free Basic plan and do not have access to additional subscription plans. For more information on subscription plan availability, see here: What are the available Arlo subscription plans and how much cloud storage is available?
New Zealand is listed as supporting subscription plans so these should be available there at the listed rates.
