Install on PC and on android
  • 1 Reply
  • 2787 Views
Baraban
During the activation I install arlo on my PC, after I desided to check my cameras on my Adroid phone.
I'm not ableto log in from the phone.
If you mean you're trying to set up the base from the phone, the phone must be on WiFi, using the same network as the base.
 If the system is already set up and you can't log in from the phone, try uninstalling and reinstalling the app.  Be usre you know the email and password used when setting up the system.
