  • 5 Replies
  • 8027 Views
  • 3 Likes
dguilloryjr
I have a Arlo base station model: VMB3010r2
Is there a way to have more than 5 camera's active. I remember at one time that the base station had a limit of 5 camera's but not it looks as if i can add another camera. I figured I would ask the group because, I don't mind getting another camera, I just don't want to get another camera and then get a message after I add it saying that I can not view the camera. So question is am I limited to 5 camera's are can I add more camera's.
5 REPLIES 5
You can have more cameras;
1) upgrade your account to a paid service
2) get another system, open second account with diff pw/email and then GRANT ACCESS back to system 1
As @TomMac says, you will either need a paid subscription or use a second account (with another base) if you go over 5 cameras.
Another aspect is that the base station can only handle 5 simultaneous streams.  So I do suggest adding another base along with the camera - whether you use a second account or go with the paid subscription.
dguilloryjr
Is there another base station I can upgrade to that will handle more than 5 camera streams?
dguilloryjr
Also is there any like data sheet on the bases that will show how many simultaneous streams each can handle.
I believe all base stations are spec'd at 5 simultaneous streams.
There is a summary of the differences here, but that doesn't show that particular aspect.
 https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
The closest thing to a spec on this I know of is here: https://kb.arlo.com/1179521/How-many-Arlo-cameras-can-I-view-at-the-same-time
