  • 6 Replies
  • 10030 Views
henriet
Hi
I add my arlo account under IFTTT, i success to add a button widget on my smartphone but when to add a applets "tell google assistant to arm your arlo", on Which device section no device appear.
Thank
6 REPLIES 6
brh
My understanding is that Arlo's IFTTT is not completely functional these days. Someone correct me if I am wrong.
Brian
henriet,
This issue is currently being investigated by the Arlo development team. I will post an update as soon as I have more information.
RobertRosal
Virtuoso
Virtuoso
Problem can be easily duplicated.
If this, works, it's the then that, that does not.
For example.
If DLink motion is triggered, then Arlo record. - This does not work and cannot find Arlo camera
If Arlo motion is triggered, then turn on light. - This works because it can find the Arlo camera
-Robert
henriet
Best regard
henriet
The problem is not solved
henriet
IFTTT and Arlo don"t work
