IFTTT Arlo, Lutron Caseta triggers
I use ifttt to trigger security lights on my garage if the camera detects motion. I'm looking for a way to set this parameter for a certain length of time so that I don't have to manually go into the app and turn the garage light back off.. Any ideas.?
You could try Stringify, which gives all the features of IFTTT but with additional abilities
Or you could set up a separate applet in IFTTT that says If Garage Lights are on for a certain length of time, to turn off
Thanks. I will look into stringify. Caseta doesn't seem to offer the ability to function with a timer like wemo does. Also I have been having trouble with the arlo trigger. Seems there have been issues with arlo and ifttt since Sept or so?
Looks like in order to get my arlo cameras and lutron caseta Lights to automate the way I want I will need to incorporate a Samsung smart things hub. Looks like caseta isn't compatible with stringify and arlo hasn't been working lately with ifttt.
Bummer it doesn't work as is but yay for getting Smartthings. Smartthings is awesome
