Hi
I want one of my Arlo cameras to operate from 23.59 - 08.00 each day in live recording mode. Review the information the next day and then delete from library.
(1) Can I schedule the camera to do this or will I just have to set the live recordng manually and stop it manually ?
(2) In doing the live recording as above will this diminish the battery life very quickly,and will it have any impact on the storage capacity in my library as a Premium subscriber ?
Unless I missed something you can't schedule a recording. It either starts when motion is detected, and then only for a max of 120 sec or start manually when it will go to standby 30 min later. Extrapolating my battery use I estimate you'd go through a set of batteries in 12-16 recording hours.
Hi
Thanks for that. I'll take a new look at that particular issue.
