I have no broadband and no router, only LTE
  • 2 Replies
  • 2067 Views
GHS
I need to plug a network cable from the base station to a router. I have no broadband and no router as the location is remote but have LTE.
What is the cheapest solution? Preferably your product? Thanks
GHS,
The base station needs to connect to a router (with an internet connection) to communicate with the Arlo cloud. You may be able to use an LTE hotspot device with a router to accomplish this, but the devices required for setup would depend on the LTE device you are wanting to use.
For more information on Arlo minimum requirements, see here: What are the minimum requirements for installing and using my Arlo system?
If you have an LTE hotspot with no Ethernet port, you could use a WiFi extender that connects to the hotspot WiFi and then connect the base to the extender
