I have 8 basic Arlo cameras but does not have a SmartHub. Is VMB3500 compatible?
  • 1 Reply
  • 1705 Views
MSGArmy93
I just bought a house. It already has 8 basic Arlo cameras both inside and outside the house, but it does not have a Smart hub or any attached to it. The previous owners took it with them. I was looking at the one Smart hubs on line that are compatible with the my Arlo cameras (3500 series), but I do not know if they will work. Will this one work?
Any of the bases/hubs will work with these cameras so you're good. Note that the batteries are likely dead and will need replacing. Also, if you have contact info, you should check to see if the previous owner has removed the cameras from their account. I don't think there's an issue but it would be nice to know.
