I cannot cancel my monthly subscription.
  • 7 Replies
  • 2533 Views
Angry1
Just like sooooo many others, I can't cancel my monthly subscription.  I've tried ALL avenues offered through Arlo's "support".  Unfortunately, the selections they say to click on are not available on my.arlo.com or my mobile Android app.  Please help!!!!
7 REPLIES 7
Do you see "Library" in the app? Or do you see "Feed" and "Dashboard"  instead?
Angry1
In the app the Library option is at the bottom.  On my.arlo.com I see My Dashboard.
Are you using the same credentials???
Angry1
No. I use 2 different email addresses
That is the problem.  You need to use the login for the primary account.
Angry1
Thanks.  I will try that.
BrookeN
Was you able to cancel the subscription?
