I can't find a spec for the maximum distance to activate the motion sensor. Anyone know?
I can't find a spec for the maximum distance to activate the motion sensor. Anyone know? This is for the unit Arlo calls "Arlo". Model# VMB3000. Thanks, Steve
That's is the original base/camera setup...
The original Arlo HD camera has a max range of about 20 ft for the PIR that detects motion.
