I can not add more than one rule to a mode.
  • 5 Replies
  • 3858 Views
EverLink
I can not add more than one rule to a mode. I have defined two rules: "record by motion CAM1" and "record by motion CAM2" but i can't assign both of them to a mode. The clicking on a rule works radio button like only. I have tried it on IE11 and Chrome as well.
What I have to do?
5 REPLIES 5
The rules should show up in the MODE automaticly after saving and in there are toggled on/off with a green/black check mark
( all modes contained the same rules, just some are turned on, some off )
After you added RULES, check you ALL MOTION ON and see if they are in there ( all should be green checked )
FPh
Bonjour ,
J'ai supprimer une option : détecter tous les mouvements
comment remettre cette option sur le menu svp
Merci
FPh wrote:
Bonjour ,
Merci
Add a new MODE,  settings/mode/ADD ( right side of page )
Call it ALL MOTION ON, make sure every camera line has a GREEN check mark at the end.... SAVE
EverLink
TomMac, thank you for your help. I thought it works as you have mentioned, but it seems no. Please take a look for my video on
https://www.youtube.com/watch?v=12-DKkSWyBw&feature=youtu.be
You'll see my problem. Any idea?
Thanks... as you know , it's not supposed to work like that. Picutres worth a thousand words tho...
But the answer may not be easy either...
1) try and reset the base via the power button....
2) if that does nothing, it may require a full factory reset ( and re sync of the cameras too )
