I bought the VMS3530 - Which cameras are those?
I bought the vms3530. which cameras are those? those are the pro cameras? They don't hook up to a solar panel. I have a solar panel i thought i could use when I purchased. brand new in box if anyone wants it that can use it...
will the VBM 3500 work with those cameras?
They should be the Arlo WireFree cameras (which use four CR123 batteries).
There is no charging port, so they cannot connect to a solar panel.
