  • 8 Replies
  • 4575 Views
  • 5 In Conversation
JKES
After trying to download an update that failed, hub and cameras are offline.  I have reset the hub & the router but nothing happened.  The three lights on the hub are all green.  The routers shows my hub and the MAC address.  How do I get online.
JKES
Problem solved:  I had to deactivate the Hub & cameras and then reactivate them.
8 REPLIES 8
JKES
rdgwd
Not to revive an older thread, but I just starting having this hub / camera offline issue the last couple of hours and it's about to drive me insane.  Do you have to remove the hub, active the hub, remove the cameras and re-sync the cameras?  Or just remove/add the cameras through the app?
Oh, if I still had the ole wood chipper!  Smiley Frustrated
Have you power cycled the base?  Is there a chance that the Internet connection is flaky?  What are the LEDs on the base showing?
alganon
I'm having off line message problems . Three lights on the base , batteries good in the cameras , changed password , power cycled base , opened / closed battery door on one camera , re-synced two cameras . I got message alerts and video on my phone when I triggered them with movement but they still say offline when I try to view the live feed .
It's making me crazy .
No answer here. Open a case with support.
alganon
How does one do that ? I tried last night for an hour and got nowhere .
Alg
manfredz
Hero
Hero
when I had problems initially setting up mine, I used e-mail support.  Chat I kept waiting for someone and phoning could be very expensive since no toll free number.  Since it would take 24-36 hours to get a reply wasn;t the quickest, but worked fine and in the end they established problem was a defective base station and shipped me a replacement.
In case you weren't able to find it for some reason, use the Contact Support link at the bottom here.
