How to stop the cloud storage prompt?
  • 6 Replies
  • 3289 Views
  • 2 Likes
Retired_Member
Not applicable
Nearly every time I sign in to Arlo, I'm prompted to sign up for cloud storage.  The only options it provides are "Yes" and "Maybe Later", but there's no option saying "No and never ask me again".  How do I turn this black-hat marketing off?
6 REPLIES 6
Delete any zones you may have defined. Those require either a subscription or AC power.
Retired_Member
Not applicable
Your response is much appreciated!  I had to check what is meant by 'zone' since I don't recall defining any. When I looked that up, I can confirm I've set up no zones with any of my cameras.
Not sure then. @JamesC , @ShayneS ?
Could you provide a screenshot of the message you're referring to?
Retired_Member
Not applicable
Thanks for inquiring!
Please see attached:
There is no way to permanently dismiss this message. I will pass your feedback along to the team for consideration.
