I would like to receive a notifications when my selected motions are detected, but how do I stop receiving continuous notifications while still recording what is going on in my business should I need to review if I suspect theft or other things against company’s best interest.
Hi Caps311,
If you are referring to the push notifications on your iOS or Android device, feel free to read here on how to enable or disable push notifications:
- How do I enable or disable Arlo push notifications on my iOS device?
- How do I enable or disable Arlo push notifications on my Android device?
If there are certain times that you would like to receive push notifications, you could also try using the schedule mode and/or create custom modes. You can read more about it here:
