I use Arlo cameras for my home under one account and use Arlo cameras for my office under another account. How can I get access to ALL of my cameras through the Arlo app? I can't find out how to make that work, given I have two separate accounts. Ideas are welcome. Thank you.
Share the cameras from account A to B ( look in settings for grant access)
Thank you @TomMac . I can't seem to find that option in the desktop version of the website anywhere. Can you direct me more specifically? Does it have to be done via the mobile app? Thanks.
I just looked further @TomMac and looks like you can only do it through the mobile app after all. Thank you.
It can be done on both the app or web...web is easier
go to the FAQs and read up, or go to settings , click on Grant Access and follow steps
OR
You can go up to a paid account and use either 10 or 20 cameras total depending on account level
https://kb.arlo.com/000039122/How-do-I-add-friends-to-my-Arlo-account
Well I have two basestations, total of 5 cameras to cover my home and my GF's. That is as easy as adding the second basestation under Devices. Then cameras in the normal way. HTH...
