  • 1154 Views
Ajejeb
All my automations disappear , I am not able anymore to understand how can I schedule a turn on at 9PM and a turn off at 6AM independent from the geofencing. The new app is horrible!
Thanks to anyone who can help
Can you post screenshots of the automations you are using now?
General approach:
  • use Arm Away only when away from home
  • schedule mode changes between Arm Home and Standby while home
  • Schedule automations are enabled in Arm Home and Standby, but not in Arm Away
  • Geofencing Arrive is only enabled in Arm Away (not in Arm Home or Standy)
  • Geofencing Leave can be always enabled (though ok to just enable in Arm Home and Standby).
Ajejeb
This is not what is possible to do with the new app, this was possible with the old one
Not sure what you mean.
Can you post screenshots of your automations?  It sounds like you have set the enable lists incorrectly, but it'll be much easier to sort that out if I can see the screenshots.  I suggest masking out the map in the geofencing automations to protect privacy.
