How to add a 2nd base station to another location?
First, do you have at least the Premier account? That would get you the 10 cameras that you say you should be able to get. If so, remove the inappropriate cameras from the existing base, add the second base when you're on-site and sync those disconnected cameras to the second base.
Ok, now I have it. You need two accounts so each can have 5 cameras. Each account needs a base with appropriate cameras synced to it. Then use Settings, Grant Access from one account to the other account's email address. That will allow you to see all cameras on one login.
Another, less than useful option is to set everything up on one account and manually deactivate cameras and move others to active so you get a mix of cameras that work for your current needs. I think this is where you are now - all cameras are on one account but you can only have 5 active at one time.
