How to access local hub storage from outside of network?
  • 1 Reply
  • 432 Views
solenol4
I can't seem to access local storage from outside of my home network.
I have poet forwarding set up on my router to the port listed in the app. Is there a tutorial or guide? Maybe I missed something.
I have port forwarding set up on my router to the port listed in the app. Is there a tutorial or guide? Maybe I missed something.
Try checking that the forwarded port is open by running https://canyouseeme.org/
It's possible that the ISP is using CGNAT (which doesn't allow port forwarding).  Another possibility is that you are accidentally double routing.  If you have a modem/gateway in front of the router, then please provide the manufacturer/model information.
