How to access local hub storage from outside of network?
I can't seem to access local storage from outside of my home network.
I have poet forwarding set up on my router to the port listed in the app. Is there a tutorial or guide? Maybe I missed something.
Message 1 of 2
428
I have port forwarding set up on my router to the port listed in the app. Is there a tutorial or guide? Maybe I missed something.
Try checking that the forwarded port is open by running https://canyouseeme.org/
It's possible that the ISP is using CGNAT (which doesn't allow port forwarding). Another possibility is that you are accidentally double routing. If you have a modem/gateway in front of the router, then please provide the manufacturer/model information.
Message 2 of 2
417
