How to access local hub storage from outside of network?
  • 1 Reply
  • 56 Views
jiwacfa1
I can't seem to access local storage from outside of my home network.
I have poet forwarding set up on my router to the port listed in the app. Is there a tutorial or guide? Maybe I missed something.
Since port forwarding is a router setup thing, you'd need to look in your router's manual.
Generally, you should set your DHCP server in the router to provide a set IP address for your hub since a reboot may get a different address, breaking the port forwarding. Once that's configured, use the app to go to the hub's settings, Storage Settings, Local Storage Settings to enable port forwarding. Once you accept the risk banner, the app will display the pertinent information to be used in the router's settings.
