How do i use the Pan and Zoom on the app
  • 1 Reply
  • 3217 Views
angelfig119
New to Arlo. How do i use the Pan and Zoom on the phone app. or the laptop. all i can do is Zoom.
steve_t
Master Master
Since the cameras aren't motorised, they can't actually pan or tilt. You can only zoom and then pan around the original FOV to make sure you're covering one particular area with the original FOV. Not really worth using IMO but some people have said that it kinda tricks you into thinking the lag between motion detection and recording is less if you zoom a bit on the center
