Can I control the power of my arlo from my mobile device ie switch on/off?
Under Settings, pick camera, toggle on or off
that makes the camera offline till turned back on ( there is no real off switch)
It should be noted that the On/Off switch currently has a bug that allows the camera to still detects motion and will activate the IR illuminators (if enabled) even when the camera is supposedly off. It just doesn't record.
