I do not have either email or push notifications on for the camera by my garage but I continue to get email notifications when there is detection. All of my cameras are set up the same way and all of the sudden I started getting notifications for this particular camera. Help!
Try changing the order of your devices. This fixed an unrelated issue I had with the camera selectio in mode.
Just to be thorough, the mode isn't All Motion On, is it? If so, more steps are needed, starting with a system reset.
I did also remove the camera and re added it..
All motion on is not selected.
Help - these notifications are crazy lol.
If the above doesn't help, it's time to drop back and punt. Remove all devices in Settings, My Devices and start fresh. Note your settings and mode/rules before doing so to help with the rebuild. Power cycle the base and open and close all battery doors, ensuring that the batteries are good. Use the Add Device button on the Devices tab to add the base and sync the cameras. Check for firmware updates (which may have been the problem in the first place). Set up your settings and create your custom modes again. It's a PITA but should clear the problem.
reed918,
Consider a factory reset as suggested above by jguerdat. Do you still see the same behavior?
