I can't seem to find out where to change noticifation settings in Schedule Mode?
Schedule really isnt a MODE tho it is listed there... If your using ARMED when you set up your schedule , then the mode your using is ARMED
All schedule does is turn on/off the mode you plug into the time slots
You must exit the schedule ( turn off ) and then edit Armed ( if thats what your using. )
If it doesn't take, then power button cycle your base unit.
You don't change it in the schedule...
You drop out of schedule and edit the same mode you were using in the schedule
FAQs are your friend
Yes I looked at the FAQ's and I already did this.
When I click on MODE i see
ARMED
UNARMED
SCHEDULE
GEO
I changed the notifications and took the checkmark out of email in the "ARMED" mode
Then went back to Schedule mode.
I am still getting EMAILs
Drop out of Schedule by using Disarmed
Go to MODE > the mode your using and > to edit
Pick camera
edit
Uncheck the email/pushes
SAVE
repeat as needed for each camera
I gues I am confused about what "the mode I am using" means?
The "mode I was using" was scheduled. But like I said I cant change camera notifications in there. The only other option is in "Armed" where I have unchecked the email notification for both cameras. I am still using push notification to my app on my phone. That is working fine. but then I get an email also
