How do I stop email notification in schedule mode?
  • 5 Replies
  • 6440 Views
jeffkics
I can't seem to find out where to change noticifation settings in Schedule Mode?
Schedule really isnt a MODE tho it is listed there... If your using ARMED when you set up your schedule , then the mode your using is ARMED
All schedule does is turn on/off the mode you plug into  the time slots
You must exit the schedule ( turn off ) and then edit Armed ( if thats what your using. )
If it doesn't take, then power button cycle your base unit.
5 REPLIES 5
You don't change it in the schedule...
You drop out of schedule and edit the same mode you were using in the schedule
FAQs are your friend
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-set-up-notifications-or-alerts/ta-p/10...
jeffkics
Yes I looked at the FAQ's and I already did this.
When I click on MODE i see
ARMED
UNARMED
SCHEDULE
GEO
I changed the notifications and took the checkmark out of email in the "ARMED" mode
Then went back to Schedule mode.
I am still getting EMAILs
Drop out of Schedule by using Disarmed
Go to MODE > the mode your using and > to edit
Pick camera
edit
Uncheck the email/pushes
SAVE
repeat as needed for each camera
jeffkics
I gues I am confused about what "the mode I am using" means?
The "mode I was using" was scheduled. But like I said I cant change camera notifications in there.  The only other option is in "Armed" where I have unchecked the email notification for both cameras.  I am still using push notification to my app on my phone.  That is working fine.  but then I get an email also
