How do I manually set an IP address and DNS for the base station?
Dig out your router manual. You can't set it in the base so you'll have to configure your DHCP server to do this. Of course, the DNS server will then be used for all devices using DHCP. The IP address setting will be found nearby so the base gets the same address all the time. However, the little reason do do either one.
