I have two routers & therefore two LANS--how do I know which LAN the Arlo systems is on? And, I'd like to put the sys on the most powerful LAN--but how?
First, the bases connect to your network via an Ethernet cable so whatever you've got hooked up is where it's connected.
Second, the cameras never use your WiFi - they only connect to the base you synced them to. Your WiFi has no bearing unless it's interfering with the base-camera connection.
Thanks for the speedy reply
