How do I get the audio to work on my Arlo camara?
In settings for my device the Audio/Video is shaded. How do I get audio to work on my Arlo from Netgear?
On a pc log into your account at https://arlo.netgear.com/#/login and see if you can fix it there. It could be an app problem.
What is the model of the camera and what smartphone and operating are you using?
Brian
