THE ARLO CAMERA,,,,I GET MOTION VIDEOS 10 SECOND,,,,,IS THERE A WAY TO GET LONGER THEN 10 SECOND VIDEOS,,,,,,,,,,,,,,,,,,,,,,AND IS THERE A WAY TO WATCH LIVE VIDEO CONTINUOUSLY ,,,,THANK U
A slight edit to the above instructions for adjusting recording length:
Log in to your Arlo account and navigate to Mode > click pencil icon next to the mode you want to edit > click edit next to the desired rule > click the pencil icon next to Record Video.
From there you can adjust the slider to the desired video length. Be sure to Save when finished.
How do I adjust the video recording length?
To increase record time, go to;
Settings
My Devices
Beside Armed or mode (you want to edit)
Click the pencil icon/edit
Rules , then pick camera you want
hit edit ( pencil )
use slider bar to increase record time up to 120 seconds.
click Save
Live streaming max is 30 minutes.
Continuous video recording, or CVR, is an optional feature available on Arlo Q cameras. CVR records all the action 24/7 so you can rewind any camera to any minute of any day and catch anything you missed.
Check this link, https://community.netgear.com/t5/Arlo-Knowledge-Base/How-does-the-continuous-video-recording-or-CVR-...
i have attempted to extend the record time for my cameras via the web access, does not appear to be available, it appears that you can only do this thru the app, where you can see the pencil/ edit option when you click on the Mode tab at the bottom of the screen
the other issue is that i cannot extend the recording time for the cameras on a schedule mode, only in the armed mode
how do i extend recording time for the cameras on a schedule mode, where i can manage the arm/disarm time
the discussions show that you can set another mode up, however does that mode then record all the time? and it appears you can only set that mode for one camera....
thus: how do i set up a schedule for cameras, and set the sensitivity and length for each individual camera?
