  • 1 Reply
  • 11023 Views
horim80
Hi
I would like to know how to do factory default the base station and camera.
and if I do that factory default, the base station will be deactivated? so I can do new system setup again?
  • Perform a factory reset on your base station.
    Push the Reset button (on the back of the base station) and the Sync button (on the side of the base station) for about 10 seconds or until all the LED lights on the base station blink amber. This procedure returns the base station to its factory settings. If your cameras were synced to the base station, you might need to sync the cameras again after the base station comes back online. For more information, see How Do I Set Up And Sync My Arlo Cameras?.
