Heading Out Soon? Do This Quick Camera Check First
Before you pack the snacks, find the chargers, and confidently forget at least one toothbrush, give your Arlo setup a quick pre-trip once-over.
Heading out soon? Here’s what’s worth checking before you leave. A few minutes now can save a lot of frustration while you’re away — and help keep your vacation from turning into a remote troubleshooting session.
Battery levels — Make sure cameras have enough charge to last the trip.
Motion alerts — Confirm notifications are working and tuned the way you want them.
Activity Zones — Check that zones are covering the important areas, not your neighbor’s very dramatic tree.
Camera placement — Look for anything blocking the view or causing extra motion triggers.
Wi-Fi signal — Make sure each camera has a solid connection before you’re 600 miles away and bargaining with your router from a hotel room.
Need help stretching your camera battery life? Check out https://kb.arlo.com/291/How-can-I-extend-Arlo-camera-battery-life
Anything else you check before leaving home? Share your pre-trip camera checklist in the comments!
