  • 12 Replies
  • 20159 Views
galefau
I keep getting the "getting status" message now on my phone although everything was working fine earlier today.  I can connect to my cameras via my computer but not my phone.  I have tried logging out of Arlo and logging back in, restarting my phone, etc., but still keep getting this message.  I also restarted my base station but am still having problems through the phone app.  Any suggestions?
12 REPLIES 12
Have you tried both cell service as well as WiFi?
galefau
Yes, I just tried using cell service and it works.  So I guess it has something to do with my wifi.
At home or work? Work networks are a frequent issue.
galefau
At home.  I never had a problem at home on my wifi before today (have had the cameras almost a year).
Try restarting your router.
galefau
Just restarted the router and still saying "getting status."
Dang. Does everything else work from the phone on WiFi? Do you have any security settings on the router that you've changed? Or a security app on the phone for WiFi connection that may be blocking access?
galefau
Yes, everything else works on my phone when using wifi.  I haven't changed any settings on the router or the phone.  I was able to access the cameras using wifi this morning and then a few hours later didn't work.  I can't imagine what changed.  And I can actually hear the push notifications when motion is detected and get the email, but cannot change modes or check devices.
Makes me think it's an ISP problem.
galefau
But I can access my devices through my computer, just not my phone when I am on wifi.  Could it still be an ISP problem?  And if so, what would I need to do?
Good point. If it were ISP-related, it should affect all devices.
Do you have another mobile device to try? Perhaps have a friend try at your house on your WiFi. The only other thing I could suggest would be a factory reset of your phone and rebuild but no guarantees that would help.
galefau
I think I will try reinstalling the app on my phone and see if that helps.  Thanks for all your help anyway.  Much appreciated.
