Getting re-connected again
  • 2 Replies
  • 1437 Views
stefano8
Hi folks
would really appreciate some guidance from the community.
I have Arlo Wireless HD cameras (the 4 battery model) and XLs.  I ran these through the hub I received when I purchased the originals in 2017. Having moved house, I had to leave the hub behind, as it supported the Arlo doorbell.
Question I have is, what do I need to purchase to reconnect up my existing cameras, to my 5G Home Router.  (the area I am living in demand security cover)
Any guidance would be truly appreciated
Thank you
Stef
The currently sold hubs are the VMB4540 and the VMB5000. The main differences are that
  • The VMB5000 is dual band (2.4 ghz/5ghz), the VMB4540 is single band (2.4 ghz)
  • The VMB5000 has microSD slot for local storage, the VMB4540 has a USB port for that.
  • The VMB5000 costs more.
Both support your 2.4 ghz cameras, so I'd just get the less expensive smarthub.
Note you will need to get ethernet to the hub, so double-check that your broadband router has a suitable LAN ethernet port.
stefano8
Hi StephenB
Thank you for your help, much appreciated, and sorry for taking so long to acknowledge it.
Many thanks
Stefano
