I tried the Geofencing mode which works OK for mobile devices but not for a computer. After switching it on then switching back to Disarmed (or any other mode) the computer will not show live feeds.
mulgabill,
Live feeds can be viewed regardless of the active mode. When live streaming, the mode is temporarily disabled for the duration of the stream and will return to the active mode once the stream is ended.
What are you seeing that is indicating an issue with live streaming when Geofencing is enabled? Are you getting an error message when attempting to live stream?
