General OS query for mobile
  • 3307 Views
Minburn57
Hi there
Having to upgrade a mobile device and for the first time considering either iOS or Android based.
Is there one of these OS's that works better with the Arlo mobile app?
I use both android S7 phone and Apple Ipad .... and tho I am a hard fast PC guy, I will have to say between the android and apple , If i had to pick one it would be IOS.
They both have pluses and minuses , i just think over all. the IOS is slicker
Minburn57
Thanks Tom.
Ive used this Arlo system with an ipad for quite a while now and the odd delays aside (which may or may not have anything to do with the apple device), it has worked reasonably well.  It is just I've never used an Android based device before and there are some features in the android option other than Arlo app that are appealing to me.
Well, then good luck which ever you choose.... it's like they are both fruit but ones an apple , ones an orange  🙂
