  • 1 Reply
  • 1624 Views
AJW1911
Following a power cut, cant reconnect
steve_t
Master Master
Try a power cycle of the base and battery  pull reset of the camera. Failing that, you might need to remove all devices, do a hard factory reset of the base, and start from scratch adding the base and then syncing each camera
