Elapsed time between notifications
  • 1 Reply
  • 14685 Views
dane
Is there a way to set default time elapsed between notification? Right now if motion is detected, notifications keep happening if there is move,ent every few seconds. Would like to set not to notify so frequently.
Also anyways to choose to recieve notification on certain cameras and not all?
4vrnvr
The only way to set this would be based on the length of your recording. So if you set recording to the max of 2 min you would only get one every 2 min. An enhancement request has been submitted to allow for setting times between notifications but no idea if that will happen.
Under modes you can turn off notifications for any cameras you have.
Greg
