Downgrade Firmware
Is there anyway to downgrade the firmware on the cameras. From the time I installed the latest version my cameras are always loosing connection. I have to remove the battery and put them back in for it to reconnect. The base station is only about 30 feet from each camera and the system is in the same setup it has been for a long time. The only change was the firmware.
Or maybe the camera is bad. Try removing it from Settings, My Devices and resync it. If it still happens, use the Support link above to create a trouble ticket for more help and maybe an RMA.
