Does the Arlo Pro Base Station have a better range than the Arlo Wire-Free Base Station?
Does the Arlo Pro base station have a better range than the Arlo wire free base station? I want to upgrade if it would help the signal to the cameras.
They all basically have the same range. Moving the base via a long cable or WiFi or powerline extender may help. Otherwise, a second base can be used which would be positioned close to the problem cameras.
