Disabling/limiting data uploads
I recently bought a Netgear Nighthawk mobile router via AT&T to use in my RV, I then bought another Arlo cam(I have 3 for the house). The router I bought is set to work with arlo as a base station. My fist trip using it, I burned through about 25gb of data in 4 days. Is there a way to disable/limit data transmitions? I had everything set to lowest resloultuion and record time but it still burns through all my data in a few days.
How much total time per day are you using for recordings and live view? Minimizing that usage is needed.
