Device order
  • 26 Replies
  • 3262 Views
  • 8 In Conversation
becpb
I'm unable to change the order of cameras when viewing "Devices" on my iPhone using Arlo App 6.3.0 or my laptop using "https://my.arlo.com/#/cameras_new".
In both cases clicking on the three dots allows me to move the images but after clicking "Done" the images return their original order and an Error message: 'Device order change failed'. I have tried deleting the app and re-installing it, but same problem.
BrookeN
Please update to 6.45.0. and the behavior you are seeing should now be resolved.
Best answers
  • BrookeN
26 REPLIES 26
Try and via the web browser ( firefox works for me )...
go to DEVICES
Hit "3 dots" on upper right
Screen should show wiggling cameras which you "drag - drop" for order
becpb
No luck!
BrookeN
Can you try uninstalling and reinstalling the app?
Hog72712
That’s the last sentence of the original post.
I’m having the same issue.
What phone, OS and app version are you using?
It is working for me on an iPhone 12 mini running iOS 26.5.  The app version is 6.31.1.
Hog72712
6.31.1 on an iPhone 16 Pro Max. I get the same error as the OP when trying this on my iPad as well.
Hog72712
this is the error I get when trying to reorder devices.
BrookeN
Can you update the firmware and see if you still see the same behavior?
Hog72712
I have two base stations, firmware is current on both of them. I don’t see a way to update camera firmware on each camera.
Go to each camera's settings to click on Device Info, Firmware to check for updates.
Have you tried that lately?
I am not seeing the check for update option anymore for many of my cameras. I am seeing them for some though.
For instance, the original Ultras don't have it, though the Ultra Gen 3 models do.  The Pro 6 has it, Some essentials have it (for instance the VMC3050 and VMC3070), as does the outdoor pan-tilt.   But not the AVD1001, the Wired Floodlight, the VMC2050 essential,  Pro 2,  or the VMC3052.  That last one is odd, since the VMC3050 still does show it.
As you know, I use the iOS app.  Edge just shows "no updates available" for all my devices (with no check for update control for any of them).
@Hog72712:  I am wondering if @BrookeN meant to say "update the app".  I have 6.34 on my iPhone, so likely there is something newer than 6.31 available for you.
BrookeN
I should have specified, yes I did mean to update the app.
BrookeN
Are you still seeing this same behavior, or had it resolved.
Hog72712
I am still seeing the same issue, my iPhone and iPad app are both up to date. I have been busy with the holiday and haven’t had a chance to respond.
BrookeN
I have reached out to our development team, they will be looking into this. I will update you as soon as possible.
becpb
Yes
josephistired
Any update on this issue?
BrookeN
This is still being investigated, I will update the community as soon as possible.
BrookeN
This behavior you were seeing should now be resolved. Can you please let me know if you are still seeing this same behavior.
josephistired
I am still getting the error. I tried reinstalling the app, but no luck.
Version: 6.36.0 (31343)
Hog72712
I’m also still having this issue. Not resolved, using iPhone app.
becpb
Not resolved - still getting error
Edinburgh_lad1
@StephenB I thought the 'check for updates' option is visible on those cameras that connect directly to WiFi (even when they're directly connected to WiFi), whereas those that don't, don't have it.
If this isn't the case, the dev team should have the same approach across the board.
josephistired
It's been almost a month, any luck on this?
