Since yesterday, the device display shows "just now" on all cameras instead of 2 hrs. ago or 6 hrs. ago, etc. on my pc, displays ok on my android phone.
Thank you whoever at Netgear fixed this. It appears to be working correctly now.
If it works fine on yr phone, it may be the browser...
try clearing the cache or reboot the computer
I see that on occasion but a refresh of the page clears the message and uses the correct info.
I've tried resetting. Clearing cache. Clearing cookies. Clearing local and session storage. Still shows "Just Now" as the time. 😞
--Darin
have you tried using a different browser?
I see the same thing for the past couple of days. I use Chrome and tried flushing cache, etc. too but no luck. Firefox does the same thing.
I have escalated this topic. I will post an update as soon as I have more information.
I have been having the same problem. Tried different browsers, cleared cache, etc... works fine on my phone, but not on the computer.
Same is happening on my system.
Thanks to all that have responded, I should add that now 3 PC'S all show the "just now" but my android phone still shows the correct time history.
Same here, working correctly again this morning!
Yes , my system has returned to normal now, thanks for everone's help.
