I just set up my Arlo security cameras last week they have been recording movement I deleted some of the clips of movement and seems like since I did that I no longer have any alerts or clips of movement I'm not sure where to go to correct the issue thanks
First, never delete videos since there's too many folks that have then wanted them back, which isn't possible.
However, deleting videos isn't the problem here. What are the motion indicators for each camera in the Devices tab (3 bars and a dot for the app or a running man for the web) showing? Black means armed, gray means disarmed. If gray, check your modes to see what one is selected (Mode tab, click on your base and view the available modes). Either use a custom mode or the default Armed mode.
It may be worthwhile rebooting the base in case something got weird there.
